View Full Version : 1972 Deville 472 tranny failed
bpeesy
04-14-08, 04:35 PM
I'm helping a friend with his Caddy witha 472 engine 125k miles, the transmission has failed. Neither of us are sure what type of tranny is in it, but I believe it's a TH400 . question: would a th400 from a 73 pontiac bonneville bolt up? the bonneville has a pontiac 455 engine. I'm not sure they match up. thanks th
cadillac_al
04-14-08, 10:44 PM
They should be identacle unless somebody changed something. Just verify that the oil pan is shaped like Texas, the vacuum modulator is on the side and the tailshaft housing is the same lengh; should be long tailshaft. It's very hard to kill a th400. I have never done it and I still have every th400 I ever owned. Somebody must have hauled a big trailer with that Caddy.
drmenard
04-15-08, 07:25 PM
I think only the caddy has the long tailshaft... the whole transmission must be taken apart to change the tail....look for a transmission from a 68 to 76 RWD caddy....
carnut
04-16-08, 10:41 PM
Describe the failure. Wont move, slips, leaks wont upshift from 1st??
kevin666
04-17-08, 06:32 PM
Why not just have it rebuilt?
bpeesy
05-01-08, 04:03 AM
That was my suggestion, but for some reason he just want to change the unit out. probably because it's cheaper. He has found a THM 375. it looks the same but we have yet to install it.
cadillac_al
05-01-08, 11:02 PM
What happened to the Buick Trans? The 375 will need a different yoke.
NYJets53
05-08-08, 08:58 AM
Well, What Happened?
buzzcut0
03-16-09, 05:32 AM
If any body is listening the 375 has a 350 output shaft but is a 400. All A/P have the long shaft rabbit ears housing .
BRUCE ROE
06-13-09, 02:26 AM
A THM375 is a downgraded version of the THM400. It doesn't have as many clutch plates, etc, and should NOT be used behind a 472.
BRUCE ROE CLC 14630 Advisor
steelybill
06-14-09, 12:59 AM
YUP!! what Bruce said.:)
