clcmbtn
04-11-08, 10:18 AM
Hey guys,
I need to replace the sway bar links. When I looked them up there are 4 sway bar sizes. How do I know which one I have?
95 STS
Thanks,
Chris
call a dealer and give them your VIN and ask for the correct size for your application...
Krashed989
04-11-08, 12:52 PM
There's a sway bar on the rear of the car as well as on the front. The sway bar end links for the rear are a lot shorter. Then again that should give you only 2 sizes. So I agree with Raze, you should call the dealer and see what sizes you have.
the rears also don't have ball joints since the wheel doesn't turn, they're a solid aluminum piece w/2 rubber bushings, fronts have 2 balljoints that are oil filled...
wallace902
04-11-08, 03:36 PM
I brought a pair of front sway bar link from ebay $15.99. works great nothing wrong .Check from e-bay good luck!
