cvol
04-09-08, 10:10 AM
Hello, have not posted in some time. I own a 2000 sts with 95,000 miles and I'm starting to hear what might be a bad ball joint on the drivers front wheel.
When I turn to the right (usually on a sweeping exit ramp) doing over 20mph I'm hearing a rubbing noise that I can only assume to be the brake pad wear indicator touching the rotor. The pad is not showing excessive wear but it sound exactly like the wear bar rubbing on the rotor. The sound does not exist under normal braking.
Do you feel my assumption is correct and if so, what might a ball joint cost? I've heard that this is a common failure at this mileage. Is there any other way of confirming that the ball joint is failing?
Thanks for the assist!
