dinoscaddy
04-08-08, 10:26 PM
Anyone know which relay under the hood would work the interior lights. They were working, then ...... I checked the fuses and nothing is blown out so I'm hoping on the relay. I don''t have the owners manual.:
| View Full Version : Interior Lights Not Working On Catera dinoscaddy 04-08-08, 10:26 PM Anyone know which relay under the hood would work the interior lights. They were working, then ...... I checked the fuses and nothing is blown out so I'm hoping on the relay. I don''t have the owners manual.: 1stL 04-18-08, 11:43 PM I don’t have a Catera, but my Deville lists what each fuse and relay is for on the back of the fuse cover. I had to remove the whole big fuse cover (not just the little one) to see the label on the underside regarding the relays. Lotek 04-21-08, 01:26 AM Relay is under the left knee bolster, 2 large 1/4 turn screws release panel. Probably a headlight switch though. I forget if that relay is labelled as such but some of the relays can be swapped around to test K Storm 04-25-08, 08:34 PM type in catera user manaual (correct year) in google. | |
