View Full Version : pullin a switch
56cadillacking
04-08-08, 08:30 PM
hello. i have a 1972 eldorado. i am looking to take that motor out which is shot and put in a 1970 eldorado 500. my question is will all the pumps and pulleys work with the 70 500 block? thanks in advance
drmenard
04-08-08, 10:10 PM
All the external parts are interchangable.. the 70 won't have a airpump.. you won't be able to put one on... but this is good...the 70 is higher compression and will have more power...
56cadillacking
04-09-08, 05:35 PM
THANKS FOR THE REPLY MAN. I AM GOING TO GO WITH THE 70 BLOCK AND THERE IS A PLACE CALLED ROCK AUTO THAT HAS A LONG BLOCK FOR 1620.00 WITH A 300.00 CORE CHARGE. STEVE
drmenard
04-09-08, 10:36 PM
I don't believe rock auto is going to have a 1970 500 for sale... Before I bought it I would ask for the casting numbers off the crank and heads.. the last 3 numbers on the crank should be 094 and the heads should be 950... there are vendors the specialize in these motors...potter automotive, MTS or torque Inc. ... there is another but I can't remember now...
