View Full Version : Rear Diff help SS from the "Wood" 04-08-08, 06:12 PM I know there's been a lot said about this issue... What am I experiencing when my rear end makes a "dribbling" sound under moderate acceleration? It usually happens around 40-55 MPH... or is this even coming from there? CTSV_510 04-08-08, 06:35 PM I know there's been a lot said about this issue... What am I experiencing when my rear end makes a "dribbling" sound under moderate acceleration? It usually happens around 40-55 MPH... or is this even coming from there?
I'm still trying to figure out what "dribbling" sounds like... SS from the "Wood" 04-08-08, 06:48 PM I'm still trying to figure out what "dribbling" sounds like...
Nobody likes a smart ass...
I've also heard this described as a "drone." Nobody likes a smart ass...
And everyone likes a supporting member! SS from the "Wood" 04-08-08, 06:59 PM I believe I misunderstood... LOL my apologies! What is the noise? I believe I misunderstood... LOL my apologies! What is the noise?
Classic diff whine. 4th gear 45 mph light to medium throttle.
Just roll wdown the windows or crank up the tunes. Live with it untill that doesn;t work, then get it fixed under warrantee.
I'm on my 4th, and it's making all kinds of odd noises.
-Chris Jayrcr3 04-08-08, 09:46 PM Hey trukk, have you tried any of the synthetic diff lubes? Mine is going in Monday for the diff whine plus a few other v issues. I have some Royal Purple sitting here I haven't put in yet in case they replace the diff. Just wondering if it helps at all? Hey trukk, have you tried any of the synthetic diff lubes? Mine is going in Monday for the diff whine plus a few other v issues. I have some Royal Purple sitting here I haven't put in yet in case they replace the diff. Just wondering if it helps at all?
I can ABSOLUTELY tell you NOT to use Mobil 1 Diff fluid. Mine started grinding and making all kinds of racket after installing it.
Mine goes in next monday, to have try out the GM synthetic XLR spec rear diff lube. It couldn't be any worse than the Mobil 1 that's for sure.
Some poeple on here have really talked up the AMSOIL shockproof gear oil, but I'm too lazy to order it.
-Chris ewill3rd 04-08-08, 10:20 PM The LS fluid is working wonders in the XLR, it should be fine for the V even though it hasn't been "validated" yet.
We have some in stock, shouldn't be a problem ;) Jayrcr3 04-08-08, 10:34 PM I found the white paper on the different oils about 5 min after I ordered the Royal Purple. Otherwise I would have ordered the Amsoil. I may have to order it anyway and do something else with the Royal Purple. GMBOUND 04-08-08, 11:19 PM Just placed my first Amsoil Order!
Severe Gear 75W-90
Torque-Drive Sythetic Transmission Fluid
AMSOIL Brake Fluid DOT-4 C66 Racing 04-09-08, 02:15 AM Thanks! I appreciate your support. If anyone is interested in AMSOIL diff fluids but finds ordering too hard, if you can do paypal, I'll put the order in for you at the AMSOIL Preferred Customer Program (http://www.c66racing-synthetics.com/Preferredcustomer.htm) pricing. PM for pricing info if interested.
:cheers: lollygagger8 04-09-08, 11:04 AM Mine was making all sorts of noise, and I changed mine out. I used the GM Synthetic Axle Lube SAE 75W-90 Part #12378261 and a bottle of Limited Slip Axle Lubricant Additive Part#1052358 and mine doesn't make much noise at all!
What's the LS fluid? Is that Amsoil? ewill3rd 04-09-08, 01:19 PM LS fluid is a new fluid that GM released in December.
It is a synthetic gear lube with a built in limited slip friction modifier additive.
You don't have to add the modifier.
It actually says "LS" on the label. lollygagger8 04-09-08, 02:28 PM Ya the techs at Kelley Auto told me that the additive wasn't needed, but I put it in anyways. Won't hurt at least. Works like a charm! ewill3rd 04-09-08, 07:16 PM All CTS-Vs require the additive.
G80 does not show on the SPID label on V but they all have the option.
Base CTS only requires the additive if it shows the G80 option. Robby2006 04-09-08, 08:29 PM What is the part number for the new LS fluid? C66 Racing 04-09-08, 11:56 PM All CTS-Vs require the additive.
True, but keep in mind that many fluids, such as the AMSOIL Severe Gear come with the additive already mixed in as part of the gear lube. ewill3rd 04-10-08, 07:42 AM 88862624 (US-1 Quart)
88862625 (Canada-1 Liter)
DEXRONŽ LS Gear Oil
Yes, there are a few other fluids that already have the additive built in.
Read the label.
Thanks for the reminder.
I sent an email to my XLR contact to see if he can check to see if they are validating this fluid for the CTS-V. ewill3rd 04-10-08, 09:41 AM My XLR contact is telling me to hold on until he can verify some information with the CTS team.
He seems to think that the CTS-V diff may have different lube requirements for the limited slip than the similar but notably different setup they use in the Y car.
I am hoping he can put me in touch with someone on the CTS team so I can find more info.
Don't rush out and buy this stuff. It may work, but it may end up causing chatter. If one of you guys is willing to be a guinea pig I guess that is okay but I don't know anything official yet. SS from the "Wood" 04-10-08, 11:11 AM I know there's been a lot said about this issue... What am I experiencing when my rear end makes a "dribbling" sound under moderate acceleration? It usually happens around 40-55 MPH... or is this even coming from there?
So to remedy my problem, which sounds to be normal by the members of the board, is to service the rear diff replacing the fluid w/ the Amsoil product mentioned, or something of the like, right?
Thanks,
SS C66 Racing 04-13-08, 04:02 PM So to remedy my problem, which sounds to be normal by the members of the board, is to service the rear diff replacing the fluid w/ the Amsoil product mentioned, or something of the like, right?
Thanks,
SS
I think the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (http://www.c66racing-synthetics.com/Product%20Bulletins/SVGPB.htm) will help minimize wear of diff components, and it seems to do very well to prevent diff clutch pack chatter (which is another diff problem commonly noted in slow speed sharp turns), but I don't think it will cure the diff whine common to the CTS-V (and other GM diffs such as the one in the GTO) once the whine has developed. However, it may help prevent the diff whine from getting worse.
I drained my stock diff fluid at just over 10k miles on the car and had it analyzed. The results indicated some pretty excessive wear.
2006 Cadillac CTS-V Used Oil Analysis Factory Fill Differential Fluid (http://www.c66racing-synthetics.com/TestResults/CTS-V%20Differential%20UOA.htm)
:cheers: rand49er 04-13-08, 05:07 PM ... the AMSOIL Severe Gear come with the additive already mixed in as part of the gear lube.Is it detrimental to add the additive anyway? C66 Racing 04-15-08, 12:48 AM Is it detrimental to add the additive anyway?
Not mechanically detrimental. Adding too much additive will result in your limited slip diff being less limited slip. I don't have the shop manual for my CTS-V yet, but for my 02 Corvette Z06, the limited slip diff is supposed to pass 75 ft-lbs of torque to the tire with grip. If the clutch plates in the diff don't have the nominal torque because the diff fluid is "too slippery", this figure may come down slightly. I doubt most daily drivers will ever notice the difference. :cheers: ewill3rd 04-15-08, 07:53 AM No word yet on this fluid usage for the V.
I hate to bug my contact, but I might if someone really wants me to. SS from the "Wood" 05-21-08, 05:04 PM Just placed my first Amsoil Order!
Severe Gear 75W-90
Have you used your gear lube yet? Curious to know your comments on it, and whether you used any additive to go along with it? Florian 05-22-08, 01:06 AM I have 2 qts of RP left over from my CTSv days....PM me and Ill get it out to you at a more than fair price.
F SS from the "Wood" 05-22-08, 03:51 PM I have 2 qts of RP left over from my CTSv days....PM me and Ill get it out to you at a more than fair price.
F
I haven't checked, but is 2 qts enough to refill the diff? Does it already have the necessary lubricants in it, or will I have to also do an additive?
Thanks,
Shannon CTSV_510 05-22-08, 03:54 PM I'm pretty sure it's 1.5 quarts in the diff. Florian 05-22-08, 05:21 PM I haven't checked, but is 2 qts enough to refill the diff? Does it already have the necessary lubricants in it, or will I have to also do an additive?
Thanks,
Shannon
2 will get you filled and then some. The modifyer is already added.
F 2 will get you filled and then some. The modifyer is already added.
F
I got seconds, if SS doesn't take em:) |
