Would it be possible to fit a TH325-4L transmission to a 368cid with the 4-6-8 ? I guess the tranny itself should fit since the stock tranny is a TH325, but will it prevent the 4-6-8 from working ? And will it be thought enough for the torque the engine produce ? With the current gaz price, I'm thinking more and more about doing that swap.
davesdeville
05-26-04, 04:11 AM
Thought the TH400 was stock on a 368, or TH425 on Eldos.
Well, it is on a 1981 Seville, maybe there wasn't enough room for the TH425 !
davesdeville
05-26-04, 05:33 PM
Ah the Seville, I always forget about the Seville. Well Sevilles had 350s not 368s, so it wouldn't be too easy.
lux hauler
05-26-04, 07:11 PM
The only 350 offered in the Seville in '81 was the Olds diesel (standard equip.). The V8-6-4 was optional along with the Buick V6.
http://100megsfree4.com/cadillac/cad1980/cad81s.htm
I could be wrong but I believe the variable-displacement function worked off the transmission somehow. If I'm not mistaken, to disable the system, people just disconnected a wire from the trans. If that is true, I doubt the trans will work.....there may be other issues too.
davesdeville
05-27-04, 04:17 AM
Christ, I'll shut up now.
Ok, thanks, that is what I wanted to know.
Yes, there's a switch on the tranny when it get on third gear to tell the ECU it can switch to 4 or 6 cylinders, but I didn't know if the TH325-4L had that switch too. :hmm:
lux hauler
05-27-04, 05:24 PM
Christ, I'll shut up now.;)
but I didn't know if the TH325-4L had that switch too.Like I said, I could be wrong but if the switch was only used for the V8-6-4 function, I don't see why they would carry it over to another trans that it isn't needed on.
