View Full Version : What do you find the most luck with for treating the plastic of the ext bed cover ?
Spectre
05-25-04, 01:17 PM
I've had two so far and i know with the first one after a while the black bed cover was not so much black but took on a slight chalky color . Whats the best thing for protecting and enriching thi material . HCVONE has already suggested 303 protectant . But what have you other found luck with ? I was thinking maybe some z16 tire gloss on there , but again I'm not sure if that may speed the process . Ideas ? Also do any of you put dielectric grease on your seals for the bed cover ?
chant74
05-25-04, 02:17 PM
i use 303 on all my cars, my boat, and jetski... it doesn't leave the plastic sticky or too glossy. And holds on pretty well to the elements. I wolud suggest 303 protectant also.
T_Dogg8
05-25-04, 02:21 PM
this might be a stupid question, but what is 303 protectant??
hcvone
05-25-04, 02:35 PM
303 is a vinyl protectant, I used this on my boat's vinyl, plastic and rubber.
T_Dogg8
05-25-04, 02:38 PM
can i find it at an auto store?? and is it just called 303 protectant??
fast66
05-25-04, 04:47 PM
Is there a way to remove scratches from the rear bed covers?
dirty-red
05-25-04, 07:42 PM
i have been using armor-all, but i will try the 303 when i get back home(i am deployed right now).
hcvone
05-25-04, 10:37 PM
It's in some stores and sold at many boat supply stores
msheri01
05-25-04, 11:27 PM
GM recommends a product called armordillo.
TheBehemoth
05-26-04, 12:18 AM
I have never tried to clean the bed of an EXT, however there are 2 products for plastics that i have tried on various other cars and had very good success with.
The first one is Plexus. If you do a search on Autopia.org you will find that it is highly recommended. I have used it on interior plastic parts and its always worked well.
The second is the Meguire's Clear Plastic Cleaner and Polish. Now its designed to be used on convertable plastic windows, but i have tried this on non clear plastic parts and its worked well as well.
I would try Plexus first, if that doesnt work, give the Meguire's a try.
z1st
06-13-04, 07:40 AM
the best product i have found is Stoner's Trim/Shine. i used it on the cladding on my avalanche before i got my EXT. it has uv protectors and kept cladding looking like new for 2 years-no greasy oily residue, just a nice black oem look. usually avaiable at walmart.
