rjg426
04-02-08, 07:52 PM
Hello all, I'm working on my aunt's 86 Fleetwood Brougham drivers window problem. The window operates fine for about the first 6 inches, then it stops going down and the motor makes a loud ratcheting type of noise. It will go up fine from this 6 inch point.
I took the door panel off and the window does not look to be binding or off the tracks. It just stops at that 6 inch point then makes that loud ratcheting/clicking noise at the motor.
All parts that I can see of that long plastic drive tape (not sure what it's called) appear to be fine (no broken/worn out slots, not out the the regulator channel, etc.).
Anyone have any ideas about what can be causing this? It happened all of a sudden.
If the motor needs to come out, does the regulator also have to come out? Any suggestions on how to get the motor out (I tried searching but didn't get anywhere). I assume drill the rivets out, then replace with nuts and bolts.
Thanks for any help.
Rich
Rich
