View Full Version : easiest way?
johnpage
04-01-08, 08:04 PM
whats the easiest way to remove camshaft sensor from my 2000 sts. shuold i remove the fuse box first .can someone help please. thanks
peteski
04-09-08, 03:26 AM
You might want to try posting this on the Northstar forum.
Peteski
Logandiagnostic
04-14-08, 01:51 AM
I think the way in..is from under the car.
Remove the large splash shield. Reach in, and replace.
I think the sensors have 10mm screws holding them in.
Some suggest removing the oil filter adapter. I dont get it, I can get in without even touching the oil stuff.
Logan Diagnostic LLC
www.ledfix.com
www.airbagcrash.com
http://www.logandieselusa.com/deutzdiesels.html
submariner409
04-14-08, 10:50 AM
Camshaft position sensor: front of right cam cover, down low and toward the rear. Single connector, short pigtail from harness. PITA. Metal bracket just over makes it even worse. Suppose you could also pull the fuse/relay box and/or p/s pump. Still a PITA.
Logandiagnostic
04-14-08, 11:22 AM
Sorry..read it wrong.
I was thinking crankshaft sensor..
