View Full Version : 91 Caddy DeVille Sedan Belt
Grave
04-01-08, 05:39 PM
the compressor in my caddy is shot...i called around some part stores and they want around $400 for a new one...i was told i can bypass the compressor by usng a smaller belt...has anyone else here done that and if so what size belt would i need?..any help at all would be greatly appreciated...thanks
EDIT: Guess it would help to include that it's a 4.9 liter fwd...
behind-bars
04-01-08, 10:27 PM
http://www.cadillacforums.com/forums/cadillac-tech-tips/96512-94-4-9-c-belt-bypass.html
That is for a 94 deville, but since its a 4.9 I imagine it would be the same on your 91.
Grave
04-02-08, 12:27 AM
thanks a million!!!
Grave
04-16-08, 11:43 PM
after bypassing the compressor with a shorter belt all my digital stuff went out except for the radio
behind-bars
04-17-08, 01:29 AM
Sure you bypassed the compressor? if yes does the belt spin freely without jumping around?
Maybe its not turning the alternator fast enough or something. I'm not 100% sure what would cause your problems.
CadiJeff
04-17-08, 04:06 AM
I did it on my old 88 seville for the same reason, never had a problem with it.
Grave
07-31-08, 03:51 PM
now the bolts in my water pump pulley came loose...could this all factor from the belt not properly fitting?.
