View Full Version : Northstar engine swap
hemiboy
04-01-08, 02:11 PM
I have a 1997 Seville STS. It has a blown headgasket and is knocking. I have purchase a 2004 engine and transmission complete on the K frame. What is needed to switch out the motors? I know I need to use all of the electrical harness from the 1997. Can I strip the block down to a long block and use the rest of the accesories from the 1997? What needs to happen and can this be done? What are the differences between the motors?
AJxtcman
04-01-08, 05:25 PM
The only way this may be possible is if you use a harness and PCM from a 00 to 02 Eldo. You may need to swap out the ABS module with one from the later Eldo also. If you had a 99 Deville I beleive the 00 eldo PCM will work in the 99 Deville without swapping the ABS. :thumbsup:
zonie77
04-01-08, 11:26 PM
There were major changes between 99 and 2000 series engines. While it can be made to work it is much easier to find the right engine.
