View Full Version : Converting a 4wd to a 2wd
tones_d_man
03-31-08, 05:39 PM
Hey guys,
I was just wondering if it is possible to get something to disengage the all wheel drive on my 2005 Escalade. There is a empty spot in the dash where the controls should be located (to the left of the Odometer) If there was wiring behind it and I got the switches would it simply disengage the all wheel or am I missing something on the transfer case ie. servo??
Yes I know "If you wanted better gas millage you should'nt of bought an Escalade." Please see the Silverado attachment 40819
HITMONEY
03-31-08, 07:39 PM
The short answer is "No", you cannot.
Here is some info...
http://consumerguideauto.howstuffworks.com/your-ride-4wd-vs-awd-cga.htm
hcvone
04-01-08, 08:47 AM
Well of course anything is possible, but would be costly to do, in the long run it would probably be cheaper to sell your truck and buy a 2 wheel drive truck. :)
tones_d_man
04-01-08, 10:31 AM
I don’t see explaining what the differences of Awd, 4wd and 2wd has anything to do with what I am trying to achieve. Does anyone know what "costly" entails. That is my question.
ZaC851
04-01-08, 05:09 PM
probably going to have to change the rear differential from a 2wd escalade, tahoe, yukon etc, new rear output shaft from the tranny and new rear tail housing on the tranny. Its probably not gonna be cheap.
DaveH28
04-01-08, 10:48 PM
Actually the rear diff will probably be the only thing you won't need to change... There's no reason to change the rear diff.. there should be no difference between a 2WD rear end and a 4WD rear end, it is mounted the same way and has the same style pinion flange so it takes the same type of driveshaft..
Depending on what you're trying to achieve --
If you want to keep your truck as a 4WD instead of an AWD, you'll need a different transfer case, a different TCCM (transfer case control module) and possibly a different PCM (powertrain control module), TCM (transmission control module), or both. You also may need and EBTCM (electronic brake & traction control module).. Those might be able to be re-programmed with different software rather than replacing them but the TCCM is different. You'd also need to run all the wiring from the switch to the transfer case and the modules. That wiring to the switch does not exist on an escalade.
Now if you wanted to switch from AWD to 2WD, it's a major undertaking.
You'd need:
A different transmission extension housing and output shaft
A different rear driveshaft
2 different front hubs/bearings (not sure about the spindles/etc)
A different PCM
Possibly a new EBTCM
A damn good reason for doing a project like this :)
That's it off the top of my head, there's probably more :)
