Tailfin
03-31-08, 01:21 AM
Just looking for some moral support on this one. I'm very familiar with the 4.x engines, but never worked on a Northstar before, so those of you who have...
This is for a 97 Deville. I was on the highway, and all of a sudden I see "engine hot," "idle engine," then "engine overheated," "stop engine," all while I was still in the process of pulling over. I shut it off as fast as I could, and turned the key to the AC position to see the coolant temp, and it was around 250-something :bomb:. The oil life also went immediately to 0%, but I checked it at the stick and it looked fine; I'm assuming it did this because oil temperature is a factor in the oil life.
So I let it cool down, and had a fun 6 hours of doing that and coasting to where I needed to get in order to avoid being gouged by a towing bill. I checked the coolant level after it cooled down, and it needed a bit, but I soon found out that wasn't the problem. I checked under the car--no drippage. I checked the cap again, and the coolant was still up to it, so it didn't leak away, and no headgasket suspicions.
I checked and also found I had no heat. So basically...it happened rather suddenly, it has coolant, there's no heat, and the engine overheats quickly, oh, and the upper radiator hose was hot, so I don't think it's the thermostat stuck closed or something. So me thinks the water pump went. There was one rogue code in there, but I forget. If it would help, I'll post it, but I'm assuming it's just telling me it overheated. It was P12____ something like that.
So my questions--anyone disagree and think there's something else it could be besides the water pump? The only thing I could think of was a blockage in the system, but it didn't seem likely that it would prevent engine cooling and cabin heat. Also, as I recall, this blasted car requires a special tool just to get it's water pump off--can I get that at a typical place like Advance Auto?
If we all agree this is definitely the water pump, could someone give me a basic run-down of the procedure for this? Actually, a link to another thread would be just fine since I'm guessing this one's been covered. I apologize for not searching this, but I'm completely whipped from all the coasting tonight. I haven't...until now :bigroll:...been *ahem* motivated to get a factory service manual for this car... It's just approaching the 100,000 mile mark. I have no knowledge if this was replaced or not, as I bought it last year, and I've put about 20,000 on it.
