Amax86
03-31-08, 01:01 AM
2001 DTS, 4.6L northstar
A few months ago i started having surging and RPM at idle rapidly varying from around 300 to 1500. My local mechanic changed the O2 sensors, but i started having the same problem about a week later. The latest error code reads something like "camshaft position sensor" and another reads "camshaft sensor circuit malfunction". I just bought a replacement camshaft sensor to install. Is the sensor relatively easy to replace? Is this a common problem with this engine model?
Also, i have read about some problems that occur from the crankshaft position sensors being bad and a lot of them sound like the same problems i am having although im not getting any error codes regarding the crank. Could my crankshaft sensors also be bad even though im not getting any error codes?
Any advice would help. Thanks in advance.
