View Full Version : WTB: In-trunk CD changer
Jen_Kenne
03-29-08, 02:17 PM
I have a very low mileage 1999 Catera.
I am looking for the trunk mounted CD changer.
Army_MP_From_MO
03-29-08, 03:56 PM
If you find one that supports MP3s, and is compatible with our Bose system, let me know.
Jen_Kenne
03-29-08, 04:48 PM
MP3s are no problem. I have a 4.95 adapter from my MP3 player into the cassette. Check out Le Target, Radio Shack, Amazon, or many others. I own about 800 CDs and don't want to rip them down, so I hope to find the changer.
sccatera97
03-29-08, 08:13 PM
I saw one on craigslist (Atlanta) this week. It was the Pioneer. If you have a Bose system, iy is factory wired. If not you will have to get the adapter harness. If you need it, I have a line on the harness.
elvin315
03-29-08, 09:14 PM
If you have the Bose System this unit is Plug & Play.
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=65500&i=581G190CAD&tp=132
Elvin
Army_MP_From_MO
03-29-08, 10:02 PM
I was talking about a trunk mounted multiple CD changer that plays MP3's that are burned to a disk. Most that connect to the factory Bose radio support CD-R but not a CD-R loaded with MP3s.
Jen_Kenne
03-29-08, 10:33 PM
Elvin
Thanks, Elvin!
Jen_Kenne
03-29-08, 10:35 PM
I am not aware of such a device. I'm not a fan of MP3s, since it is a lossy format, but they are convenient on a little SD card.
sccatera97
03-30-08, 03:28 PM
I have a factory CD changer in my car and I use CD-R in the MP 3 format with no truoble.
Army_MP_From_MO
03-30-08, 03:36 PM
You rock! The only posts I could find about this was from a while back and everyone said that you'd have to buy one from a brand everyone hated! Looks like I'll be buying one from the stealership after all. :thumbsup: Thanks!
sccatera97
03-30-08, 03:36 PM
There is on on eBay right now that look like one I have. It expires today in about 5 hours.
Army_MP_From_MO
03-30-08, 03:39 PM
I appreciate the heads up. I'll take a look. Jen, you hear that?
sccatera97
03-30-08, 03:41 PM
This is the item number:190209546966. You will have to get the correct bracket to mount it but you should be able to find it on eBay as well.
Army_MP_From_MO
03-30-08, 03:50 PM
Ok. I found this one too: 180228259469. I noticed the part numbers and model numbers are different. This one says it works in a Catera. Not sure if it is or not
sccatera97
03-30-08, 04:08 PM
The one I have is CDX-M 2116. It is made by Pioneer for Delco.That one you are talking about seems very high. I have had this one in more than one vehicle with no problems.
Army_MP_From_MO
03-30-08, 04:21 PM
I noticed it's pretty pricey, guess he thinks it's worth more coming out of a Corvette. lol
Jen_Kenne
03-30-08, 05:52 PM
The Delco unit is identical, regardless of which car they use - Cavortte or Catera. The last one on eBay was priced at $65. That seems reasonable since the Crutchfield unit (don't know if it's Delco, Sony, or other) is $243 with a one-year warranty.
Army_MP_From_MO
03-30-08, 05:58 PM
Found another: 180228267484
andergar
03-31-08, 09:49 PM
So I'm trying to understand these posts. Am I to understand that any Delco unit will work in a Cat? It will match the plug in the trunk, will play MP3's and work with the steering wheel controls? Please help me understand.
andergar
Jen_Kenne
03-31-08, 10:00 PM
andergar
I hope you are correct. Externally, the Delco units appear to be the same, and were made by Pioneer. If the electronic plugs are the same, they should work. The best thing are the prices - which I have seen starting just above $60, although there is one made of gold with an asking price of $240.
There MUST someone on this fora that knows the answer? Please?
Jen_Kenne
03-31-08, 10:08 PM
Sorry - this was intended to be a question, not a statement of fact. I have found that the Delco units use a Pioneer cassette, and are (probably) made by Pioneer. Can any reader confirm this?
sccatera97
04-01-08, 08:33 PM
I have a Pioneer / Delco unit in my Catera. I put it in and it uses the fatory installed cable (if you have a Bose system the cable is already installed). The steering and radio controls work the changer with no problem. The button on the left side of the wheel control the song and changing of the Cds and the ones on the right control volume and radio / tape / CD function. Here is a picture of mine installed:
http://i251.photobucket.com/albums/gg307/hhatyagle/100_0782.jpg
andergar
04-01-08, 09:18 PM
So sscatera97, where did you get your cd changer, does it play mp3's and was your cd changer made just for a catera? I'm trying to see if all Delco units are universal for GM cars. There are a couple of good prices on ebay for some out of a Chevy.
andergar
sccatera97
04-01-08, 10:00 PM
I burn MP3 format on CD-RW and it palys with no problem. I got mine from a local Pontiac dealer who had it left over from dealer installations. The only Batera specific item is the mounting bracket and I got it off eBay. AS long as it is a 12 disc that has the correct plugs receptical, it should work. I had this in an Astro van (I know, what was I thinking) and removed it prior to selling it. Does your car have a Bose system?
Jen_Kenne
04-02-08, 08:11 AM
Does the mounting bracket allow the unit to swivel, or does it simply hold the change in place?
You mention 12 disc - the originals were 8 disc units.
andergar
04-02-08, 09:41 AM
Yes sscatera mine has the Bose system. Is that going to be a problem? Also, how do know if the unit has the right plug connection and does it matter if the unit plays 6, 8 or 12? Damn I'm confused. Thanks for all the info fellas.
andergar
Jen_Kenne
04-02-08, 10:41 AM
andergar
Andergar, we're both confused. The "Delco" unit seems to be made by Pioneer - right or wrong? The changer can have 6, 8, of 12 CDs, and still work - right or wrong? I wish we could come up with a Changer Model List so we could go hunting!
Jen_Kenne
04-02-08, 01:32 PM
http://i267.photobucket.com/albums/ii308/BDf8dRepTGsS/20080401_0003.jpg
I took a snapshot of what is behind the access panel. Unless I am blind, or unless the connecting cable is buried behind something, I do not see a connector for the CD changer.
Jen_Kenne
04-02-08, 01:35 PM
Factory installed cable?
Was this hidden, or tucked out of the way? See my post and photo, but I do not see a cable.
sccatera97
04-02-08, 05:39 PM
The bracket mounts it stationary. I will look in my other Catera and see where the cable is hidden. If you have a BOSE system, the cable is there. 12 Disc changers are more common. I will post the photo shortly.
andergar
04-02-08, 08:31 PM
Your right sscatera, we need a cd changer model list. Anybody out there who can help us?
Andergar
sccatera97
04-02-08, 08:33 PM
Here is what the cable that is factory installed in BOSE cars:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00066.jpg
And here is the front view of the connector:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00067.jpg
andergar
04-03-08, 02:39 PM
Looks like what I have. Sweet and you say the changer will play mp3's?
andergar
04-03-08, 02:49 PM
Okay here is a link to a CD changer for my '00 Cat, what do you all think?
http://cgi.ebay.com/ebaymotors/GM-GMC-Chevy-CADILLAC-SLS-STS-6-DISC-CD-CHANGER-DEVILLE_W0QQitemZ180229542748QQcmdZViewItem?hash=i tem180229542748
andergar
sccatera97
04-03-08, 06:17 PM
I burn CDs that were downloaded as MP3 format with no trouble. The changer you found appears to have the correct plug in but the Catera was designed for a 12 disc ( 1997 model ) so you may have to fab a mounting bracket. If it would help, I can remove mine for photo so you can get an idea how it mounts.
todd2fst4u
04-03-08, 06:48 PM
thats different than an mp3 cd. mp3 cds dont convert the songs to wave before its burnt to the cd. it leaves them compressed and the cd player will decompress and play them.
i dont think you'll find a cd changer that will play mp3 cds for the catera. im pretty sure the head unit does the decompressing and the cateras head unit does not support mp3 cds as far as i know.
andergar
04-03-08, 07:07 PM
Oh great more confusion! : )
andergar
Army_MP_From_MO
04-03-08, 11:09 PM
Here comes the great debate... again. I highly doubt that sccatera97 would have any reason to lie to us. If he says his plays them then I believe him.
