bluesteve1
03-28-08, 03:47 AM
my alarm will not stop goin' off. It has drained my battery several times and has pissed off my apt, nieghbors. is there anyway to disable the factory alarm? I took the horn fuse out so that stops the sound but the lights still flash and kill my battery. please help!!! i have a 94 FWB
THANX
Old Fleetwood
03-28-08, 02:55 PM
In the OWNERS MANUAL for my 1995 FWB, the list of fuses which you might want to pull to stop the alarm include:
"CHIME" > Number 13
"HVAC BAT" > Number 33
However, this may leave you NAKED and I have to wonder if somebody is actually testing you in preparation for grabbing your Cadillac.:thehand:
Second, if eWill is around, maybe he can chime in and come in with a better idea.
bluesteve1
03-28-08, 07:32 PM
what are the "CHIME" > Number 13 and "HVAC BAT" > Number 33 fuses? Will they only effect the alarm?
ewill3rd
04-01-08, 04:55 PM
The best thing to do is find what is setting it off.
I think usually it is the tamper switch on the trunk lid. (mounted on the lock cylinder.
Disabling it might be harder than fixing it.
bluesteve1
04-06-08, 08:48 PM
what does the tamper switch look like? if it is the problem do i have to get a new one? I really would not mind not having the factory alarm
ewill3rd
04-07-08, 07:21 AM
If it is the tamper switch on the trunk lock, remembering that it has been a while... you should be able to see the back of the lock and see the switch.
If you follow the wires you should find a connection, try unhooking it and see if the car still acts up.
My advice here may not be very accurate, I only had a couple of these and it has been a while.
Without the manual in front of me it all gets fuzzy.
If you can't find what I am talking about I might be able to locate the book and do some more research.
