View Full Version : upper strut mount making noise
jafo1994
03-26-08, 12:36 PM
So I pinpointed my turning noise to the upper area of the struts where they mount to the car on both sides. I tried loosening them and lubing them up but it didn't do anything. Can I replace these without removing the struts from the spindles. I thought maybe some spring compressors and removing the top nuts maybe I could get at it on the car. Just don't want to screw up the alignment. My understanding is the upper strut mount is replaceable.
risho
03-26-08, 07:29 PM
What type of noise is making, is it only when turning? If its a popping/grinding noise when turning I noticed with most of my cars I have owned the past it always the strut bearings that need replacing, and while your there just do the strut mounts as well.
JimD
03-26-08, 09:39 PM
....Can I replace these without removing the struts from the spindles.No. The strut mount (thrust bearing) is the piece that pre-loads the spring and attaches the whole strut assembly to the body.
I thought maybe some spring compressors and removing the top nuts maybe I could get at it on the car. Just don't want to screw up the alignment.Do yourself a favor and consider replacing the struts (if they are high-mileage parts) and the thrust bearings all in one job. If the struts are still controlling rebound, replacing the thrust bearing requires the struts be removed, broken down, R & R the thrust bearing, reinstall strut assembly, check alignment.
My understanding is the upper strut mount is replaceable.Correct.
