DIC shows 'check coolant level' about every 4-6 weeks ?
i only have to add a 1/2 cup or so...not very much.. to top it right off !
is this an oversensitive sensor or what..
with the head gasket issues of the N* , what do you guys think i'm up against??
krimson_cardnal
03-25-08, 08:42 PM
Year and model? Update CP to include will help not having to provide each time K_C
pnj2108
03-26-08, 08:34 AM
I wouldn't say HG's just yet but i would check for any leaks cause my 97 deville was doing the same thing where i had to top it off about every 4 weeks and then the leak go bigger and i was topping it off every week. So turned my car on a saturday morning but i could not see any leaks, but i then had my friend at the time accelerate the car and it was basically squirting like a water hose from the reserve tank. I got the reserve tank replace and then everything was fine.
submariner409
03-26-08, 08:34 AM
Never fill the cooant reservoir or surge tank to the top. COLD, it should be just about half full, no more. Coolant expands quite a bit when warming up to 210 degrees, the pressure cap is set for 16#, so when the "solid" expanding coolant rises to the cap it just blows out. The system is designed to run properly with an air/gas head in the surge tank. There have also been several posts concerning a cracked surge tank purge line nipple (on the upper side of the tank).
What car, year, model, mleage ? Hummer, Honda, Hupmobile ???
its a 2001 DTS. yeah it certainly could be leak somewhere else - as opposed to an HG issue. i just automatically assumed the HG may be getting weak !!
i only ever fill it to the line when cold. but its funny, it never needs much to top it up - seems like the 'low coolant' sensor goes off when its a 1/2 inch below the 'full' line.
Being an '01 it is much less likely that it is a head gasket. You need to locate the leak. Dried Dex leaves a whitish residue. Check the surge tank and radiator side tanks.
http://images.corvetteforum.com/images/smilies/cheers2.gif
