View Full Version : air ride suspension
Cadi_Ken
03-25-08, 08:29 PM
whats up?! I Just purchased a 1984 coupe DeVille with 54,000 original miles. I want to put an air suspension on her. I was wondering if anyone could recommend a setup to go with. And if possible somewhere that would be able to install it in the New York city area.
Old Fleetwood
03-25-08, 09:22 PM
For the installation, you're on your own.
But the idea got me curious and I Googled up
AUTO AIR SUSPENSION
and came up, real fast with
airbagit.com
They show $1,295.00 for a complete kit for 1961 thru 1996 Cadillac Fleetwood Brougham RWD automobiles.
Heck, go give it a shot.:D
Cadi_Ken
03-25-08, 09:25 PM
I saw that same setup. Was a little curious because the setup is pretty cheap. I did some reserch and the entire setup from airbagit.com comes assembled, complete plug and play. I may just give it a shot
Old Fleetwood
03-25-08, 09:28 PM
Google can be your gold mine.
Go "mining" and see what other interesting parts and other stuff might be there.
Happy hunting.
Technochef
03-26-08, 08:51 AM
Airbagit.com has shitty kits.
You need to get a Phatz at airassisted.com he can get you a fleet kit out no problem
You need to figure out what type of setup you want for the car.
Do you just want simple f.b.s.s. ?
Do you want fast bag setup? Runs on Helium or Nitrogen with air.
How low do you want to lay, how much room do you want to sacrifice in the trunk for air tanks. if you run nitrogen or helium. scuba tanks are huge and have to be strapped down.
I'm working on baggin my 91 Fleet, i'm getting slam specialties re 7" dual port bags all the way around. Offset cups up front so the bag sits straight.
removing the smog pump to install a edc (engine drive compressor) a york or sanden. and a viar 400 backup compressor in the trunk.
2 ten gallon tanks with 4 ports on each. maybe more depending on what the money looks like.
your going to have to chop your exhaust before the axle cause it will rub the bag if you leave it in.
Old Fleetwood
03-26-08, 12:21 PM
I just knew there'd be somebody with the right knowledge and experience to come along and give out with the straight scoop.:cool:
