madmike69
03-25-08, 09:45 AM
Hi,
where do i find the ECM fuse ? I want to clear the trouble codes and
donīt like to disconnect the battery.
We replaced the intake manifold gasket last friday. coolant leaks.
Before that car gave codes 44+45, lean and rich, and had no power.
Set timing to 20 degrees and it performed much better. Was 16 degrees...
Still gives codes 44+45. Power is still not 100%. Canīt smoke tires...
Next friday we will put a dwell meter and the exhaust tester on.
Try to fix that problem by adjusting the air bleed valve...
Thanks for your advice...
