View Full Version : Turning off headlights?
mskittrell05
05-23-04, 10:31 AM
Is there any other possible way to turn off the headlights in a 02 Escalade without the parking break engaged?
Partiers_com
05-23-04, 12:05 PM
As of yet, we've been unable to solve the same problem, but we may put a switch between the fuse contacts of the DRL/FOG light fuse. :hmm:
slk230mb
05-24-04, 12:33 AM
On the 2002, press the dome override button 4 times within 6 seconds and the DRLs will go off. You'll hear a chime if you did it right.
mskittrell05
05-25-04, 10:07 AM
This sucks not being able to turn off the headlights...What was GM thinking?
slk230mb
05-25-04, 11:03 AM
Let me clear myself up a bit, not only does using the dome override turn off the DRLs, its also turns off the auto-headlights, allowing you to turn them on and off with the switch.
T_Dogg8
05-25-04, 11:15 AM
my dad had a caddy from the early 90s that had four options, off, automatic, parking, and on. that's how i think all cars should be now. if you want to turn them off, you can, and if you want to use the automatic turn-on, you can.
mskittrell05
05-25-04, 11:30 AM
I have tried pushing the dome overide botton in 6 times really fast and it doesnt work..??
mskittrell05
05-25-04, 11:32 AM
I have an after market headunit...Could this feature have been disabled when the new deck was installed...??
