View Full Version : 4.1 dampener pulley bolt
rootercycles
03-24-08, 08:02 AM
Help! I need a dampener pulley retainer bolt for my 1985 4.1 Deville! I have contacted a couple of GM dealers to be told that has been obsoleted. I have looked all over the internet without luck and no used auto yards is going to mess with this for less than $50. Where else can I look? It is a 16mmX1.25 pitch and 30mm long.
ehall
03-24-08, 09:05 AM
Do you have a Fastenal in your area? They will special order bolts and they are usually a few pennies
rootercycles
03-24-08, 05:57 PM
yeah, I ordered what I needed today. The high strength bolt and washer will be here wednesday.
ehall
03-24-08, 09:59 PM
did you break $1?
rootercycles
03-25-08, 03:09 PM
$8 or something including shipping...
carnut
03-26-08, 11:54 PM
That engine if original had no retaining bolt! There was a factory installed piece of cork ( like one in a wine bottle) inserted in that hole. A bolt installed is a good idea, but was not there originally!!
rootercycles
03-27-08, 01:38 PM
no bolt? Really? There isn't anything that seems to hold it in there other than centrifical force and the belt. Doesn't sound right...
carnut
03-27-08, 02:33 PM
Its pressed on from the factory. It should not simply slip on like some other engines. If it comes off easily then the bolt is necc.
rootercycles
03-27-08, 03:18 PM
I did have to get it off with a puller, but I am surprised it is just a "pressed fitting". I'm going to go ahead and put the bolt I have on to make sure. Got enough problems with this thing without the dampener falling off!
carnut
03-28-08, 05:38 PM
I just looked at my 84 Eldo with 80,000 miles. It has the cork in the crank pulley! The threads in the crankshaft are there to enable a puller to remove then reinstall the dampner.
dhuberasu
06-05-08, 11:54 PM
I have a 1985 Fleetwood Brougham with HT4100 and would also like a dampener bolt....was the 16MM x 30MM with 1.25 pitch end up being the right one? I cannot find combination on fastenal's website....do you have part numbers?
thanks
david
