View Full Version : Well got the Maggie on. Scotty7751 03-23-08, 12:25 PM Took me about 23 hours total started yesterday and finished last night. I started it up and the fuel line wasnt cleared of air so it was a MAD tick and i got really scared but it cleared up. One Problem i am having is that my tensioner pully is slipping and i am loosing power and when i go WOT like a quick throttle rap my tensioner will stand straight up and my belt wil lose tension and i end up jumping my belt any ideas? rand49er 03-23-08, 01:03 PM Two quick ques:
1) What size belt do you have?
2) Do you have the belt routed properly?
I'm sure you've done your homework on these, but thought I'd ask just to get things started for ya here. stkshkr 03-23-08, 01:04 PM Use a Gatorback heavymetals 03-23-08, 01:37 PM I am sure you put on the replacement tensioner(?)
There is a "modification" from Magnuson to reduce the belt hop (I am still waiting for mine).
If you try to make it jump off you probably can.
The major increase in torque makes it very easy to do. Scotty7751 03-23-08, 02:57 PM yes i did put on the new tensioner. i dont have some of those answers but i will later the car is at my shop. SuperV_Rob 03-23-08, 06:40 PM Do you happen to have a part number and source for the GatorBack belt?
Thanks,
Rob
Use a Gatorback rand49er 03-23-08, 09:21 PM Do you happen to have a part number and source for the GatorBack belt?
Thanks,
RobGood Year
Gatorback
PN 4061037 SuperV_Rob 03-23-08, 10:24 PM Thanks a million, I have two on order from Amazon. I am not looking to throw a belt the first time I hit the gas...
Good Year
Gatorback
PN 4061037 Scotty7751 03-24-08, 01:36 AM ok now i pose a new problem my belt might have ust been wet last night well 2 hours ago on the test dive it wass running great no slippage or anything we i was cruising about 60 and went down to 4th nothing violent at all everything went good and i let off at 90 and cruised back down to 60 well i said i would try 3rd and i put it in 3rd with the clutch still in getting my rpm up to speed and let the clutch out and eased into it and it went wheeeeeeeeedoooooooooooo and it died dont know if it is missing the fuel or spark are there any common problems with the fuel stuff? rand49er 03-24-08, 05:49 AM ... wheeeeeeeeedoooooooooooo ...Are you running a Magnavolt? What size injectors do you have? rand49er 03-24-08, 06:00 AM ... There is a "modification" from Magnuson to reduce the belt hop (I am still waiting for mine). ...Is this different than the standard Dayco tensioner PN 89222? Scotty7751 03-24-08, 10:54 AM yeah its a magnavolt. and it is whatever injectors came with the magnason. If i try and start it its will putt around and stuff and die. rand49er 03-24-08, 12:21 PM In the past, others around here have gone through Magnavolts like Democrats through mistresses. Could that be your problem ... huh, I mean Magnavolt, not Democrat? Scotty7751 03-24-08, 12:33 PM In the past, others around here have gone through Magnavolts like Democrats through mistresses. Could that be your problem ... huh, I mean Magnavolt, not Democrat?
LOL Is there a way to check the magnavolt? Good luck getting it all up and running right Scotty :thumbsup: Scotty7751 03-25-08, 11:17 AM Ok figured it out it is blowing the fuel pump mtr 30 amp micro fuse. I talked to magnacharger its the magnavolt harness there is a upgrade if your fuse holder is a soft rubber one Venomous-V 03-25-08, 11:31 AM same problem i had.......kept blowing fuses, ended up that where i routed the wires from the trunk to the magnavolt was over the rear axle. when shocks compressed, it pinched the wire. ran new wire in different place and all is good. Scotty7751 03-25-08, 12:06 PM I will have to check that |
