View Full Version : HOw do you remove the battery? want to move it to left side
Bismarck
03-23-08, 04:19 AM
I want to swap the air box and the battery but I keep looking and cannot figure out how the heck the battery is held in place.
http://www.ls1tech.com/forums/attachment.php?attachmentid=104677&d=1189226573
hcvone
03-24-08, 09:37 AM
Should be clamped on the bottom toward the inside of the engine bay, there is a bolt thru a rubber block that holds the battery, a socket with an extension will remove the bolt, they the battery will lift out, you will need a way to hold it on the other side, that is the hard part, but if I remember correctly there is a plate on the side with the air box that could be drilled and tapped to hold the battery, it will take a little work but anything can be done
