View Full Version : Catera front door panel
retho78
03-22-08, 02:05 PM
How to take to off the driver's side front door panel on a 98 catera?
sccatera97
03-22-08, 09:25 PM
I have some pictures to help. It really isn't that hard. First, pull the tweeter off, pull straight out and disconnect the wire:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00044.jpg
Use a smaal screwdriver to remove the orange locking piece from the lock knob:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00045.jpg
Remove the screw from the sleeve behind it:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00043.jpg
Use a small screwdriver to remove the inner part of the handle of the door pull. You need to use the screwdriver to pull this little tab down to remove it:
http://i251.photobucket.com/albums/gg307/hhatyagle/DSC00041.jpg
There are two screws behind it. Two that are covered by little caps near the front edge of the door. There are several across the bottom that are hidden in the carpet. I think there are 5 or 6. This should get you where you need to be.
retho78
03-25-08, 04:20 PM
Thanks for the information, will give a try and let you know.
sccatera97
03-25-08, 05:49 PM
I forgot to tell you. That is the top of the handle. Push the screwdriver between it and the door panel to push it down. Pull out from the top.
