richbanta
03-21-08, 08:31 AM
I am getting ready to do the rear discs on my caddy. Any issues I should be aware of? Never done the rears but have done the front. Are they the same. Thanks
Rich
BTW: I did an insert job on my northstar last oct using the inserts I found on ebay. (solid, simple inserts) They seem to be working great and much more inexpensive then some of the other kits. I just bought the inserts and already had the drills and taps I needed.
grgrose
03-21-08, 11:48 AM
The back disks are pretty much like the front disks. If you cant find a shop manual, get a Haynes manual or something like that. It won't be as detailed but it will steer you in the right direction.
krimson_cardnal
03-21-08, 12:03 PM
As with the fronts, no need to pull the brake line. Caliper will swing up. The rear caliper pistons need to be rotated in to spread them [e brake issue], not a straight forward compression. Look here: http://www.cadillacforums.com/forums/suspension-brakes-tires/85041-rearbrakes-96deville.html
Some use a pair of needle nose pliers to do it, but the cube is an easy piece to find, Auto Zone will lend you a kit, least around these parts.
Use the brake lube you get w/ the pads on all moving parts of the caliber assembly sparingly to assure the slides are not going to hang. Should be no problem for you. K_C
blue_eldo
03-22-08, 05:50 PM
The biggest pain is the parking brake cable. I unbolted the small bracket to provide cable slack to disconnect the cable. Then I rebolted the bracket before I did the swing into final position. I also open the bleed valve, and bleed into a container filled with fluid, while retracting the piston.
Make sure you jack the car high enough to get the wheel back into that stupis skirted wheel well!
krimson_cardnal
03-22-08, 08:06 PM
Forgot about that cable. As I recall it became a real pain in the butt. I was able to avoid opening the bleeder though. Wanted to avoid it, actually. Had no problem turning the piston in. I did need to crank it up a bit to get the wheel in there, good point. K_C
