DocVB
03-20-08, 03:27 PM
Howdy, new to group. Have a '05 ESV Escalade, owned since new, plenty of prior GM experience with Suburbans.
Having problems with the passenger rear brakes. Had to replace pads 1st at 25K miles, now again at 45K miles. Dual-piston calipers look fine, no leaking fluid, pistons easily pushed back. Did both rears at 25K miles, 3 pads were moderately worn but the innermost pad on the passenger rear was shot.
Pads were, however, a bit tight when inserted into their slots when replaced. No apparent corrosion or rusting in the grooves they slide into, plus the smaller metal inserts in the cast iron "frame" are fine looking--no crumpling, no warping.
Pads on other makes are always much looser in their mountings. Is this a problem in the Caddy? Is this the problem as opposed to a caliper in need of a rebuild? Or should I merely grind the pad's end tabs down a little bit for a bit of a looser fit in the mounting slots?
These are specifically the pads for the dual-piston rear brake setup.
Just looking for any input from the fellow Escaladers. Hopefully there are some others with the same experiences.
