AJxtcman
03-18-08, 09:26 PM
Hey I just built a solid front mount for a 2003 DHS:shhh:
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0116.jpg
It feels great. It is not rough or abrupt at all
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0117.jpg
AJxtcman
03-18-08, 09:28 PM
Hey I had the intake painted also
http://i224.photobucket.com/albums/dd25/AJxtcman/Bert/HPIM0114.jpg
This was the start of it.
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/intake/Intakewiththefuelrailonthecar2.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/intake/Rearview.jpg
AJxtcman
03-21-08, 08:26 AM
List of NEW & OLD Mods!
Solid front engine mount - Adds a ton of throttle response on 00 to 05 FWD car. No bad side effects. Soon I will have this available.
Camshafts - I am working with a major manufacturer The spec have been loaded into the design software and they have the numbers all done. They have not ground one yet. I am going to deliver several OE cams so they can profile the lobes first. Soon I will have these.
Pistons - Ross makes pistons, OE replacements come in over sized for some years. I can get you a set
Connecting Rods - Eagle make a rod
Block Repairs - TimeSerts or Norms Inserts repair pulled head bolts
Head Gaskets - Cometic make a MLS gasket for some or all years.
Head Bolts - You can easily upgrade any 2000 to 2003 to 11mm X 2.0 threaded bolts over the 11mm X 1.5 by installing the 11mm X 2.0 TimeSerts and buying the 2004 head gasket kits. BTW LSX use the 11mm X 2.0 X 30mm inserts
Exhaust - Cat back systems work great!
CAI Systems - If you buy one it may need some attention before it fits, works, looks good, and you may still loose power.
Fuel injectors - This will help. I know from personal experience with customers cars.
Modified Fuel Pressure Regulator - This will work on 95 to 99 car, but you need a Stainless Steel fuel rail and you can't go too high on the pressure or it lock the injector up. I can get you one of these
Intake Manifolds - Can be cut open modified and reassembled. I have seen this done and I have NO idea if it does anything!
Throttle Bodies - You can install one, but I think it will be at a loss! you need to search out the people that did this and find out what happened
Transmissions - Shift Kits are available and have produced excellent results. I can get you this
Torque Converters - 3000 to 3500 stall speed works well. I know that the last VIN Y factory tested at 1800RPMs, but the VIN is higher and I thought it was 2600, But I bet that is wrong! I can get you one of these also.
Gear Ratio Changes - This is a big help for performance also GM offers 4 ratios. 2.84, 3.11, 3.48, 3.71. 3.11 and the 3.71 are Cadillac ratios.
PCM Tuning - Any of the Mods listed above may not work to the level you think they should. I can make adjustments to the program to get more out of any of the listed mods. On some mods you have to have a custom PCM tune. I can up the speed limiter to 155 MPH. I can make more power on the bottom end
Example Gear Ratios: If you lower the ratio the trans won't upshift and you will hit the rev limiter.
Example CAI or Throttle Body : your car flows air better, but the PCM is not setup for it. I can make it work.
Example Camshafts: You will loose vacuum and may have an unstable idle. I can setup the PCM to correct this.
I am sure I missed some things so please add:thumbsup:
AJxtcman
03-21-08, 08:30 AM
I have a new tuning software package coming!
AJxtcman
03-21-08, 08:36 AM
Blowers Turbos Nitrous have all been used on Northstar's and Cadillac's!
This takes a lot of work of a 10 or 10.3 to 1 engine. How much boost can you run on a 10.3 to 1 engine?
Nitrous systems: I have a Modified LPE timing retard box that will help. It take 10° out! It clips in and you have no wire cutting.
I am getting ready to install Nitrous on a customers car:D
thewireman*
03-21-08, 11:32 AM
AJ, please IM me about the Modified Fuel Pressure Regulator for my 1999 Deville if you have time. Thank you.
I have tuned LSX cars with 10.9 to 1 and ran 9psi intercooled and max timing was set at 12 deg on 93 oct. some with alky spray running 12psi
to stay on the safe side just run 6psi
AJxtcman
04-21-08, 01:09 PM
new piece is 52mm plus 3mm washer
I already have corsa exhaust.. I'm interested in some more intake modifications, and fuel line mods, mounts and bushings, tranny mods and your PCM update of course. Drop me a line when any of this is ready please :) (99 STS)
AJxtcman
05-01-08, 08:09 PM
mine done yet?
This is your mount!
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0379.jpg
This is the type of mount that I am using to make it
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0378.jpg
This is the Seville type that is the same as the TSB mount in the Deville's. I am not using this type
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0382.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Northstar/HPIM0383.jpg
CadillacGurl
05-01-08, 11:53 PM
he cant wait :)
he told me to tell you the money was sent yesterday
AlBundy
05-02-08, 02:18 AM
Owwwww Jason control that temper.
