: White stuff Under Oil Cap
gixxer_751
03-18-08, 04:03 PM
Anyone have any ideas wtf this might be?? i pull off the oil cap and see white gooish like $hite under the cap and down the tube leading to the valve covers.
elvin315
03-18-08, 04:34 PM
The creamy emulsion is usually caused by water condensation in the crankcase. It's relatively harmless. Short trips will not boil off this water. Clean the cap and filler tube, then go for a long drive to clear the water.
If the "mayo" remains after long trips, check for oil in the coolant tank. . If there is you have a leaking oil cooler. It's buried between the cylinderheads in a coolant gallery. It will require replacement of the cooler, and flushing of the cooling system. Continued use will clog the radiator and heater core.
If there is no oil in the coolant tank, with the engine idling, check the tank for exhaust gas smell and signs of bubbles. If there are it's likely you have a blown head gasket. Not very common for this engine but it does happen.
Draining the coolant
http://www.cavweb-forums.co.uk/showthread.php?t=69998
http://www.omegaowners.com/forum/YaBB.pl?num=1167917774
Oil Cooler Diagrams
http://www.pbase.com/elvin315/image/72813956
http://www.pbase.com/elvin315/image/72813961
Changing the oil
http://www.omegaowners.com/forum/YaBB.pl?num=1167519662
Replacing the oil cooler
http://www.cavweb-forums.co.uk/showthread.php?t=63566
http://autos.groups.yahoo.com/group/CateraOwners/files/Cadillac%20Catera%20TSB%20%26%20Service%20Files/%20Replace%20Oil%20Cooler/
http://autos.groups.yahoo.com/group/omega_owners/files/Oil%20Cooler%20Replacement/
External Oil Cooler Mod
http://f1.grp.yahoofs.com/v1/AKHaRwEdRRRAqvc08UzrhouBIhlr3XBHQ-LqbbH5rV_iI-6d4BU-UgBtMAAUgqrVrsB9xLYVtHqL5XbAhankotSzzh-WbQ/External%20Oil%20Cooler%20Install.doc
The head gasket procedure is below.
http://www.omegaowners.com/forum/YaBB.pl?num=1187928695
Elvin
gixxer_751
03-18-08, 04:37 PM
:thumbsup:thanks for the info & wtf is up with all these advertizmnts, i know they help pay for the site but $hite making posts harder to read..
srinne
03-19-08, 10:42 AM
I agree !!!!
CateraMV6
03-19-08, 03:57 PM
I think they should switch to one of the other style forums... they are free and about 10x better for the users... I personaly hate the way this forum is set up...
Check out the Omega Owners Forum to see how much better it is...
elvin315
03-19-08, 06:41 PM
I'm starting a separate discussion regarding the Forum. It's rude to hijack someone's thread this way.
Elvin
