View Full Version : Disable keyless access
PsychoV
03-16-08, 05:47 PM
How do you disable keyless access so you can use the regular key in the door and the ignition?
Crackerzot
03-16-08, 07:24 PM
You can disable keyless entry, autolocking, etc. in the DIC setup. I can't answer your question about using a regular key in the ignition, because my car doesn't a key receptical - just the "dummy" key which stays inserted.
You can use the key inside the fob to unlock the door only - not lock it. At least, that was my experience when trying it yesterday.
