: What amp?
LS6TT
03-16-08, 05:18 PM
I have a Audiobahn Flame Excursion 12" sub. Says the power handling is 550 RMS.
I am only going to run one sub, can anyone tell me what amp I should go with? I want to spend under 150 for the amp.
thewireman*
03-23-08, 12:08 AM
MTX Mono amps are very good. Check them on e-bay. I'm pretty sure its dual 2 ohms sub right? Make sure you match the wattage with your ohms. Like if it is dual two ohms, you can use the amp that is pushing one ohm or if it is dual 4 ohms, you can use the amp that is pushing 2 ohms....etc. It can be a messy math work but it'll be worth it!
