View Full Version : 2 questions
joeg679
03-16-08, 12:08 PM
1-how do we lock the boxes on the pickup bed on either side?
2-is there a way to change the nav keyboard layout to a qwerty layout?
Thanks
Dif
03-16-08, 03:27 PM
Thanks
#1: Are you talking about the cargo boxes built into the rear fenders on the EXT?
If so, the Ignition key will lock and unlock them.
#2: Sorry, don't know.
joeg679
03-17-08, 08:46 AM
I tried the ignition key, it won't turn. Also, what os that lock next to the rear license plate?
Dif
03-17-08, 12:51 PM
Don't mean to ask a dumb question but I presume you tried wiggling the key.
I have to do that once in a while to get them open or lock them.
Only other thought is you might have to see the Dealer.
Maybe the key does not match the locks. Factory mess up maybe ??
The key hole by the rear license plate is to open the cover over a hole used to lower the Spare tire.
Put the long crank handle included with the Jack kit parts into the hole and turn it Counter clockwise.
That will lower the spare tire so you can get at it if needed to change a flat tire.
Also, if I remember correctly, you will find instructions in with the Jack Kit.
joeg679
03-17-08, 05:05 PM
Thanks. I tried to wiggle it and it still didn't work.
Cadillade
03-18-08, 05:42 AM
You have to slam the door down in order to lock them. If you can open the door without pressing the button, then you need to slam some more until the button pops all the way out. Good luck.
