View Full Version : same trouble code has come back...what does it mean
Shibby_CBS
03-13-08, 05:03 PM
so i just pulled codes from my car again and i got a current code of P0147...ive had this one before...i looked it up:
P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3
any idea on what this is saying in lehmans terms and what should i do about it...thanks guys
JimD
03-13-08, 05:19 PM
....ive had this one before...i looked it up:
P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3It means the O2 sensor at the outlet end of the catalytic converter is not responding to changes in fuel trim the way the PCM expects it to respond.
What did you do the last time you had this code?
Shibby_CBS
03-13-08, 05:22 PM
it went to history so i just cleared it to see if it would come back...sure enough it did
submariner409
03-13-08, 05:37 PM
$50 at rockauto, a wrench, a heat shield, good to go. Do the job cold, and don't touch or get any anti-seize on the sensor tip. Don't bend or twist the wiring as one of the three wires is a fragile "clean air reference" signal wire.
JimD
03-13-08, 05:43 PM
What did you do the last time you had this code?I didn't state that correctly.
It is the heater that is not responding the way the PCM expects it to respond. Check the 10A OXY SEN B fuse in the underhood fuse/relay box for continuity and corrosion. If that checks OK, you might have to replace that sensor.
Shibby_CBS
03-13-08, 05:47 PM
ill go check it right now...brb
Shibby_CBS
03-13-08, 05:54 PM
they look fine...not blown and no corrosion what so ever
Ranger
03-13-08, 09:29 PM
You can't tell by looks. Just R & R it. It is the aft-CAT sensor.
Shibby_CBS
03-13-08, 09:57 PM
R & R?
submariner409
03-13-08, 11:55 PM
In the Navy: Rest and Recreation. In the automotive jargon: Remove and Replace. Go to www.rockauto.com (http://www.rockauto.com) . Click on the pic and scroll in.
Shibby_CBS
03-14-08, 12:33 AM
alright i got ya...one more question...is thing hurtin my performance any or is it just an annoying part that eventually should be replaced...since its related for to the cats is it just for emissions?
submariner409
03-14-08, 12:39 AM
The O2 sensors also vary fuel/air ratios. That has a direct effect on gas mileage.
Shibby_CBS
03-14-08, 01:15 AM
looks like its gonna cost me arount 100 bucks...good lord...btw its a little cheaper at gm parts direct...not sure about shipping though
Ranger
03-14-08, 06:20 PM
In the Army it wa Rest & Recooperation.
