: Bad bad day
setes
03-12-08, 04:59 PM
What else can happen to me today !?
This morning some ******* tried to stole my wallet ! But it's OK, I am fine, my wallet too ;-)
I am writing this post cause there is something wrong with my Cadi.
No 2nd gear ! My tranny won't shift from 1th to 2nd or from 3rd to 2nd too.
The fluid level is OK, it looks and smells OK!
Do you think it is the end of my tranny ? (151000 miles on it)
Any suggestions ?
TIA
Paul,
JOHNNYRENO
03-12-08, 05:07 PM
i would say juist dont use 2nd, and see how long it takes too lunch the rest of gears,,:stirpot:
setes
03-12-08, 05:18 PM
What can I say.
Don't hit a man when he's down - kick him; it's easier
hcvone
03-12-08, 05:41 PM
150k miles, probably shot, hate to say it. :(
setes
03-12-08, 06:08 PM
Thanks Carl,
I expected it, I just wasn't sure if it is not some ECU / electrical problem.
I will check it tomorrow at the shop.
Regards,
Paul,
Eldo1953
03-12-08, 07:01 PM
What year is the Truck?
setes
03-13-08, 02:16 AM
It is 1999.
Till today, my transimission was OK, shifted smooth, no slips etc.
Paul,
hcvone
03-13-08, 07:49 AM
Paul, how often was the fluid changed? Have you had the truck since new? You may have not lost the whole trans, but with your high miles..........:(
setes
03-13-08, 09:52 AM
Fluid was changed every 25-30 k miles. I am the second owner of this truck.
The mileage is mostly highway, but I know 150 k miles it is not so bad.
I was at tranny shop today, they removed the pan, they found some dirt on magnet and they replaced some valves + fluid.
It didn't changed anything and ... transmission needs to be rebuild :-(
I hope next week my tranny will be as good as new one ;-)
Best regards
Paul,
TSS
03-13-08, 10:29 AM
Best regards
Paul,
If it helps any, "sorry". That is not bad life out of an almost decade old 4wd truck tranny.
hcvone
03-13-08, 01:10 PM
That sucks. :(
setes
03-20-08, 01:42 PM
OK! Just to keep you informed ;-) Tranny rebuild, Lade alive :thumbsup:
Torque converter and 2/4 gear sunshell + planetary set broken.
How come it worked :confused:
Thanks for support ;-)
Paul,
hcvone
03-20-08, 04:19 PM
Did you see the parts?
setes
03-20-08, 04:40 PM
Yes, of course. they showed me everything the day they disassembled the transmission. I cannot say anything about converter, but it's not big deal. The sunshell was broken a bit and I saw some wear at gears.
