95 FWB here. Change oil light came on today. Read the manual and tried to reset it. In fact, I tried a several times now and I just can't seem to get it to reset. I'm turning the key to the second position, just before turning it over, and depressing the gas pedal three times. No dice.
Changed the oil a few weeks ago. Checked the oil today - level is good. Color looks good. Smells ok. No problems there.
So I'm thinking I'm either doing something wrong or the sensor has gone bad.
Advice, tips, tricks, cheats anybody?
After the oil has been changed, you'll need to reset your system. To do that:
1. Turn the ignition switch to the ON position with the engine stopped.
2. Fully push and release the accelerator pedal 3 times within 5 seconds.
3. The CHANGE OIL light should flash two times and then go out.
If the CHANGE OIL light comes on and stays on for 5 seconds, it did not reset. You'll need to reset the system again.
