Hi
I have a 2008 STS With less then 200 miles on It.
When you drive over 60 mph.The Stering wheel shakes.What do you think is wrong?:cookoo:
STS2002
03-10-08, 06:27 PM
I would take it back to the dealership and have them check the tire balancing.
Hi
Thank You. That is what I though.
I will take it back the next day.
I hope this is not the start of going back and forth to return the car for stupid things wrong ?
Pete:confused:
STS2002
03-10-08, 06:50 PM
Hi
Pete:confused:
No prob...you should be ok. Be optimistic :) These are great cars! Make sure that they do road force balancing. This applies pressure to the tire while balancing. It simulates pressure on the tire from the weight of the car.
Phil
Caroutisine
03-10-08, 10:28 PM
These cars do go down the road smooth. If the stearing wheel is shaking, the dealer should be able to find the cause. Most likely a tire out of balance.
Hi
Thank You.
Just got the car back from the dealer.All 4 tires were out of balance.:welcome:
pjbizjak
03-12-08, 11:11 AM
WOW! All four tire were out of balance from the factory? Sounds fishy! You sure the dealer didn't do a tire swap before you took delivery?
Hi
Do not know but the wheel still shakes. Not as bad but still does. Maybe a bad Tire?
Pete:cookoo:
pjbizjak
03-12-08, 08:19 PM
Bad tire, bad rim even bad rotors or even tierods. Keep taking it back even though it's a hassel.
HI
I take it back on Monday. Will keep informed.
Thanks.:thumbsup:
