View Full Version : How the heck do you remove the hub at the crankshaft
Dr. Wicked
03-10-08, 03:10 AM
Hi,
I am attempting to replace the fron main seal on my '68 472. The service manual says to use a puller to remove the hub at the front of the crankshaft. Is it only pressed on? I tried with two different pullers with no luck. Do I need a special tool?
http://memimage.cardomain.net/member_images/10/web/2206000-2206999/2206330_47_full.jpg
Thanks!
zonie77
03-10-08, 11:05 AM
You aren't showing what pullers you used. There is one made for that with bolts that go into the hub.
I see rust on the hub. You have to lube it with penetrating oil or something that will help break the rust. WD40 is better than nothing but a penetrating oil is better.
blue_eldo
03-10-08, 03:26 PM
I was pulling the propeller from the shaft on my boat a few years back. I had a puller on it and it was tightened up as hard as I could go with it. I then put a penetrating oil called Kroil - "The oil that creeps" on it. I left the boat for 1 hour. When I returned, the puller and prop were laying on the ground!
You probably can't find Kroil, but use the best penetrating oil you can find. Let it soak for a couple of day also.
fleetwood76
03-10-08, 05:56 PM
Hello
The hub is only pressed on.
This subject has been up many times before. I add two links to earlier threads.
http://www.cadillacforums.com/forums/500-472-425-368/53192-500-crankshaft-bolt.html
http://www.cadillacforums.com/forums/500-472-425-368/68272-crank-pulley-balancer.html
good luck
jolle
djcwardog
03-11-08, 05:09 PM
Yep - save the cork for later. I had to buy the referenced 9/16" fine-thread bolt and a few big washers to use in pressing the hub back on.
You'll see your timing chain when you pull that cover off - and it will be LOOSE. Mine sure was. So maybe you'll want to at least replace it plus the gears with a high-quality setup that does not shed nylon teeth into your motor...
Dr. Wicked
04-03-08, 02:00 AM
Thanks guys, I used sili-kroil (you can order it directly from kano labs ;) and a steering wheel puller from harbor freight. I cracked that cheap puller, so I machined a 1/2 steel plate with a hole in the middle and four small holes around it. I put the cracked puller behind the plate, ran long 1/4" bolts through the smaller holes to the hub. That cracked it right off.
Some pics here:
http://www.phantomcoaches.org/forums/view_topic.php?id=1107&forum_id=1&page=2
