View Full Version : dangrieco
dangrieco
03-09-08, 08:37 PM
I need help BAD! SOMEBODY?
I think I might have a blown head gasket in my 94 seville!
It's missing and puttering rough. I found oil in the 3 or 8 cylinder after replacing the spark plugs,
Plus the Catalytic converter was smoking and smelling and the engine and exhaust seemed to have a pop sound.
What is all this and what can I do?
Thanks
Dan
chubbyranger
03-12-08, 07:22 PM
So far does not sound like headgaskets - that usually involves overheating with increasing frequency. Any coolant loss? You could have a plugged catalytic converter or a few othe maladies. Pull codes:
http://www.cadillacforums.com/forums/cadillac-tech-tips/55172-how-pull-codes-got-codes-warning.html
submariner409
03-12-08, 08:08 PM
The oil was probably sitting in the spark plug well, which is a slow weep from the valve cover O-ring seals at each well.
The sputtering and popping started after you did the plugs, right?
The 4-coil waste spark system requires that the correct plugs/wires go to the correct studs on each coil.
