Raider81
03-09-08, 02:52 PM
I'm a new cadillac owner and need to change plugs. Can you guys recommend some plugs should i go with Denso or Autolite or Acdelco????
2001 Cadillac Deville
78,000 miles
78,000 miles
| View Full Version : Spark plugs ? Raider81 03-09-08, 02:52 PM I'm a new cadillac owner and need to change plugs. Can you guys recommend some plugs should i go with Denso or Autolite or Acdelco???? 2001 Cadillac Deville 78,000 miles clarkz71 03-09-08, 05:03 PM AC Delco JimD 03-09-08, 05:03 PM ACDelco only. Use any other brand and you will be installing ACDelcos 10,000 miles later. And why are you replacing the plugs at 78,000 miles? clarkz71 03-09-08, 05:07 PM ACDelco only. Use any other brand and you will be installing ACDelcos 10,000 miles later. And why are you replacing the plugs at 78,000 miles? Because the platinum pads come off the ground electrodes's before 100K. I changed mine at 55K and more than half were missing causing large gaps. blue_eldo 03-09-08, 05:07 PM Stay with the ACdelco platinums. Do a search on this site and you will see verification of this recommendation. submariner409 03-09-08, 05:51 PM ACDelco 41-950, Rockauto $4.92 ea, in an 8 pack. Gap .050". You might consider buying the 8 spark plug connector boots also, same page in Rockauto, under wires/boots. Make sure the coil cassette ground spring is seated correctly with enough extension to insure a good ground. I've done plugs on only six '01-'03 STS and DTC but have not seen a missing platinum electrode disc yet. All the plugs I pulled were either Denso OEM's or, on later builds, ACDelco Japanese (Denso?) units. Two of the cars, done for friends, had less than 75,000 miles on the plug sets, and the plug electrodes looked new, with gaps from .046" to .052": completely within normal tolerances. The elusive miss problem was that one of the boots was carbon tracked in each case, shorting the plug in high humidity cold starts. You could see the spark track down the ceramic insulator. clarkz71 03-09-08, 09:48 PM I've done plugs on only six '01-'03 STS and DTC but have not seen a missing platinum electrode disc yet. All the plugs I pulled were either Denso OEM's or, on later builds, ACDelco Japanese (Denso?) units. 2001 Northstar's take a 41-987. The 41-950 is for early cars like my 1995. The missing pads on the ground electrode could be limited to the early plugs From the AC Delco web page: 2001 CADILLAC DEVILLE V8 4.6L 281cid GAS FI N Engine VIN = Y Qty (http://198.208.187.182/internet/HelpPage.jsp?helpparm=qty)Req Qty (http://198.208.187.182/internet/HelpPage.jsp?helpparm=recqty)ACDelco Part#Description (http://198.208.187.182/internet/HelpPage.jsp?helpparm=description)IGNITION / SPARK PLUG 08 41-987 (http://javascript<b></b>:displayDetails( 'ACDELCO', '41', '41-987'))SPARK PLUG, PLATINUM PLUG GAP .050 GAP PRE-SET AT FACTORY, DO NOT RE-GAP . submariner409 03-09-08, 10:57 PM Yep......clicked wrong year in Rockauto. My bad. 41-987. Raider81 04-10-08, 01:11 AM Thank you for the advice guys im ordering ac-delco from rockauto.com | |
