Moezy
03-04-08, 09:09 PM
The rear main seal and oil pan gasket are leaking.
| View Full Version : Cadillac sts '94 problem Moezy 03-04-08, 09:09 PM The rear main seal and oil pan gasket are leaking. Moezy 03-04-08, 09:46 PM BUMP. Help?:) Ranger 03-04-08, 09:48 PM You made a statement. What's the question? Moezy 03-04-08, 09:55 PM Do you have to drop the transmission to change the rear main seal and oil pan gasket? or what do I have to do? how long do you think it takes to do? Ranger 03-04-08, 10:05 PM You'll have to drop the entire drive train. Not sure how long it takes as I have never had to do it, but it is pretty involved. Someone who has done it will chime in. If it is not leaking badly, I'd live with it. Moezy 03-04-08, 10:48 PM Also I have another question, Where is the camshaft sensor located? on 94 cadillac sts Ranger 03-04-08, 10:52 PM I wouldn't swear to it, but I think it is on the rear (drivers side) of the right bank (rear) head. med 03-04-08, 11:34 PM Here's a pic for that camshaft sensor. Moezy 03-04-08, 11:37 PM hi how ru is the camshaft sensor on the passenger side or driver side and do u have to take anything off to replace it thanks Ranger 03-04-08, 11:50 PM According to that pic it is on the passenger side of the right head. tateos 03-05-08, 10:32 AM There is one bolt that holds it on - it's tight quarters in there, but I don't think you have to remove anything else. There is no gasket - an o-ring seals against oil leaks | |
