View Full Version : annoying squeek 03 EXT
03-03-08, 02:16 PM
hey guys,
i have a squeek noise that is rotational that can be hered from front and back end of the truck mostly in quiet areas such as a drive thru or underground parking and is extremely annoying:banghead:. it is only from 0-40km and only in cold temp mainly i am having a hard time trying to narrow it down..any one else have this problem? could it possibly just be the grease in the joints or boots be to cold to move around? any help is greatly appricated.
03-03-08, 05:31 PM
Check your center caps, if they are loose they are probably making that noise you hear, it drove me insane until I found it, make sure the caps are installed correctly, they is a pix of the valve stem under the cap and that should go toward the stem.
03-04-08, 01:29 AM
I had this same problem and it turned out I needed new brake pads and rotors. My dealer replaced all parts and also replaced the parking brake.
03-04-08, 11:47 AM
thanks for the help and reply's guys ill look it over. lets hope its just something minor :yup:
03-04-08, 01:00 PM
Might even be your wear pin on your brake pads.
