View Full Version : Track guys, seat belt lock
v10boost
03-03-08, 03:55 AM
Hello V owner,
Well, 08 track days are almost here. For those who do not have 4 or 5 point seat harness in your daily driver here is something you can use to hold you in place. I have used this for past 4 years and it is great product. I didn't want to put roll bar or harness in daily driver. Also didn't want to spend time installing them and taking them out for each track event.
http://www.cg-lock.com/
these things really work!
trukk
03-03-08, 12:33 PM
Hello V owner,
:yeah:
I've had them on my V for 2+ years. Great product, highly recommended if you do any spirited driving.
-Chris
Pegasus04
03-03-08, 12:47 PM
V10boost. Thanks for posting that. I knew I needed to get a seatbelt lock before we go to Summit Point. This would make a great group purchase.
Seattle CTS-V
03-03-08, 01:07 PM
I have one as well. I never take it out of the car. It works.
Nels
03-03-08, 01:11 PM
I've been using it for a few years. Great product, there will be an improvement in your driving. I highly recommend it to anyone who tracks there car.
trukk
03-03-08, 01:36 PM
Makre sure you get 2 of them, one for driver, one for passenger. For some reason, instructures don't like to have less safety gear than the driver :D
Driver side install is easy. Passenger side, does require 2 small holes to be drilled into the seatbest plastic casing.
They look good too :D
-Chris
v10boost
03-03-08, 01:52 PM
your welcome, just sharing some stuff with V owners. We bought V for one reason. to go fast.
NormV
03-03-08, 01:55 PM
Like Chris and others mention this is the ticket for a couple of track days a year.
Most clubs frown on full harness without roll cage. Because if you end up on your roof and it smashes the front seating area, the belts will keep you upright in your seat as your getting smashed. If your wearing a 3-point with or without CG lock, you'll be able to at least moved away from the crushing roof.
Not that I expect cracked sunroofs at Lindsay track day but there will be some "offs" with little run off in some areas of the Jefferson Circuit.
Norm
v10boost
03-03-08, 01:59 PM
harness must be installed with proper roll cage or bar. Other wise it could break your shoulders and do more injury than worth.
NormV
03-03-08, 02:15 PM
You learn quick. :)
Norm
Feffman
03-03-08, 03:22 PM
By the way guys, Norm is one of the instructors at Lindsay's Summit Point track day!
"No track" withdrawal is setting in. Seventy-four(74) degrees in St. Louis yesterday. Today, rain tuning to snow with 6-9 inches expected. Crimey!
Feff
www.MVPTrackTime.com
