creeker
02-24-08, 06:13 PM
Tried to find answer in "search" no luck,went to the store and c.d. player worked fine (stock 12 disc player in trunk,97 seville)when I started car again to go home,the display read "no disc" I opened access door on player and the c.d. holder did not come out as it should,the small bar light went off and on as I closed and opened the door,still wouldn't play,does anyone know what is wrong?. tnx.
CadillacSTS2003
02-24-08, 07:33 PM
unplug and plug the changer
BigOLak
03-05-08, 03:55 PM
CTS2003
This is off topic but I've been trying to get a hold of you. Do you know where I can find a schematic for how the factory amp is wired in a 96-99 deville? I want to relocate my factory radio and was wondering if I could just use the exitsing wireing behind the rear seat coming from the factory amp? Thank you in advance for any help.
(99 Concours with typical aftermarket HU problems)
I would also love to get that schematic talked about above by BigOLak. Also, would it make any diff if stock hu was relocated and amp removed all together?
