: 96 Eldorado ABS and Traction Control TRBL
thebossman
02-21-08, 02:28 PM
Hello,
96 Cadi Eldo
Shes displaying ABS and Traction Control lights. The lights are intermittant, but on more then off.
I used the on dash DTC feature and here are the codes.
History:
PC0111, PC0174, PC0603, PC1111, PC1406, PC1599, PC1626, IP2710, AC1348
Current:
PC0113, TC0027
NO: SDM, RSS, PZM, IRC, RFA, CCP
I used a DTC Codes disc, which I received with a scanner I purchased, I'm unable to locate the TC0027 code.
Where do I go from here?
John
fubar569
02-21-08, 07:06 PM
based on going from list to list and OBD1 to OBD2 code lists and making an estimated guess i'd say that "0027" isnt really 0027...but any codes i can find with "27" in them point to a "left front wheel speed sensor" malfunction of some kind...either erratic signal or general fault.
I'd start there
also:
P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
Ranger
02-21-08, 08:54 PM
T027 ........................................ LF Wheel Speed Sensor Continuity Fault
Replace the hub & bearing assembly
