: intermittent Bubbling noise in dashboard.. Any ideas?
ss6r
02-20-08, 09:30 PM
I am hearing a intermittent Bubbling noise in the dashboard upon acceleration. This 1998 seville sts has recently been timeserted and new OEM head gaskets and bolts replaced within 700miles ago. Symptoms are no overheating just bubbling in dash, could this be air pockets in the cooling system? is there a way to bleed the system other than through the pressurized coolant cap? Any help or oppinions would be greatly appreciated.
AJxtcman
02-20-08, 09:57 PM
I personally pull a vacuum on the cooling system to remove all the air from it.
It sound like air trapped in the heater core
Ranger
02-20-08, 10:17 PM
Do a search for purge line and check it. It's job it to purge the system of air so you don't have to.
ss6r
02-21-08, 12:29 AM
Thanks for your quick responses, I will investigate.
ss6r
02-21-08, 12:43 AM
Ranger I found this response from a post in december '07... thanks SS6R
Ranger
Cadillac(s): White Diamond '03 DHS Join Date: Jun 2004
Casino Cash: $4991
Re: 1995 STS Cooling problems?
The purge line is the 3/8" line into the side of the surge tank near the top. It should spit coolant at idle and flow should increase with RPM. If you could not blow into it, that may well be your problem. Locate the obstruction and clear it. It may be where it connects to the water pump housing aka crossover manifold.
Crown Vic Owner
02-21-08, 01:29 AM
mind showing me where this line is?
Submariner409
02-21-08, 10:42 AM
Crown Vic, Take a look at the pic...the surge tank ('02 STS) is on the right and the purge line is the smaller hose which comes from the side of the tank, across the air intake pipe, and connects to the w/p-thermostat housing.
Click on the image and scroll in. (Butt plug in there, too: intake resonator removed.)
Crown Vic Owner
02-21-08, 02:10 PM
Ah, ok.
Thanks.
