View Full Version : 90 eldo-possible tranny issue and engine issue
regalman4925
02-20-08, 04:54 PM
Hi, i am new on this site but i have owned cadillacs for a decade+. besides cadillacs i know a ton about 78-88 gm g body cars and small block chevys..... i am having a really weird issue with my 90 eldo. the engine has had a issue where it will just kinda cut out randomely when i am driving it which had started maybe 2 years ago then went away and then returned a few months back, i am mentioning this because it may be part of my big problem. i was driving the car one day and all of a sudden about 5 miles from home the car lost every gear and it wwould not go into drive or reverse. i shut the car off and turned it back on, it would drive for about 10-30 seconds and then die, i managed to get home some how and it actually went back to normal before i got it home. the tranny fluid looks horrible, thin and tarnished so i was thinking i have some major issues but here is what i dont get, when it is cold it drives perfect! if i go outside and start it right now i can drive all around and it will shift flawlesly..... i have not driven it far enough to see igf i have the loss of drive issue again because i dont want to get stranded. the car is pushing 140,000 and i bought it at 89000 so i am not sure if the tranny is the original or not..... any ideas???? thanks!!
cadillac_al
02-20-08, 05:24 PM
Did the tranny fluid just turn horrible the other day? I hope it's not the original fluid. If you're real lucky maybe the filter is just clogged.
regalman4925
02-20-08, 06:27 PM
fresh fluid in at least the last 15000 along with filter and gasket....... im thinking about taking it in and having it flushed so i can get all of the gross fluid out of it and fresh stuff in
Edahall
02-20-08, 07:48 PM
Don't flush the tranny. Drop down the pan and empty as much oil as possible, put on a new filter and add oil until it is full.
HUF
02-21-08, 12:00 AM
You can get rid of ALL ATF by disconnecting return line by the radiator side tank and running engine while in Park for less than a minute.
regalman4925
02-21-08, 10:05 AM
so is there still hope for my tranny? i would have asumed after seeing the fluid that it was shot but then i drive it and it shifts gears perfectly.... thanks for all of the help so far guys!
awadecki
03-13-08, 03:29 PM
Sounds like it's getting starved for fluid or the fluid level is incorrect. Try HUF's method first, or at least drop the pan and change the fluid again. NO FLUSHING!
