View Full Version : 99 Eldorado Fuel Pump Access Panel???? Or Drop The Tank???
dexec
02-20-08, 03:32 PM
I Have A 99 Eldo Etc Witha Bad Fuel Pump!! Is There An Access Panel In The Trunk Or Does The Tank Have To Be Dropped To Replace The Pump??? IF THERE IS AN ACCESS PANEL...WHAT DOES IT LOOK LIKE AND EXACTLY WHERE IS IT LOCATED???
CadillacSTS2003
02-20-08, 04:45 PM
eldo
drop the tank
Crown Vic Owner
02-20-08, 05:17 PM
is there a easier way to do it on a seville?
CadillacSTS2003
02-20-08, 05:26 PM
yea
an access panel in the trunk under the carpet towards the back of the trunk on the pass side
FrankT
02-20-08, 05:26 PM
99 Eldo = Drop the gas tank.
99 Seville/Deville = Acess panel in the luggage compartement, remove the spare tire and compartment carpet liner it's towards the rear.
CadillacSTS2003
02-20-08, 05:29 PM
you mean 00+ Deville
and 98+ Seville
99 Deville still needed tank drop
FrankT
02-20-08, 05:44 PM
and 98+ Seville
Yes, that's what I meant, you are correct.
Ranger
02-20-08, 05:50 PM
Well I'll be dipped. They put an access panel in the Seville but not in the Eldo? Guess they figured since it was to be phased out, there was no reason for a design change.
mtflight
02-20-08, 06:10 PM
Correct. The last body update on the Eldo was 1998. In 99 they changed wheels and body colored mouldings (ETC), in 2000 the new Northstar... in 2002 FIN.
