duke611
02-19-08, 09:15 PM
Hello again from the newbie cadillac owner. I ran my codes and one of them was a f32 which i cannnot find anywhere as to what this means. Any help would be greatly appreciated.
| View Full Version : 1990 fleetwood code f32 duke611 02-19-08, 09:15 PM Hello again from the newbie cadillac owner. I ran my codes and one of them was a f32 which i cannnot find anywhere as to what this means. Any help would be greatly appreciated. Ranger 02-19-08, 09:56 PM P032 (E032) ................................................. Open MAP Sensor Signal I forget what "F" means. Someone will chime in. revdowrong 02-19-08, 10:07 PM The F. means BCM codes. F32 is PCM-BCM data problem.Code F32 is set by the BCM if a problem is detected transferring data from the PCM to the BCM. Hey does F32 happen once or twice. I'm saying does it show F32 or F.F. 32. If the F only shows once its old news, if its twice its a current problem. chubbyranger 02-19-08, 10:32 PM I thought its the other way around? F32 = current, FF32 = history? Its been a while though. duke611 02-19-08, 10:55 PM It shows only once at the end of the codes and it is F32..Thanks for the info.. | |
