thebossman
02-19-08, 07:24 PM
I'm having ABS & Traction Control trouble.
I've hooked up a OBD ll Reader.
I'm getting:
IAT Sensor 1-curcuit High Input and
EGR Pintle Position.
any help?
chubbyranger
02-19-08, 08:06 PM
Doesn't quite add up, Intake Air Temp sensor and EGR should not affect ABS/TC. Try pulling your own codes without the scanner:
http://www.cadillacforums.com/forums/cadillac-tech-tips/55172-how-pull-codes-got-codes-warning.html
First off, you do not need a code reader. See the sticky in the Tech Tips section for pulling the DTC via the onboard diagnostics.
Neither of those two things have anything to do with ABS/TC. Clean the EGR valve. Again see the Tech Tips section for a tutorial. IAC sensor may need to be replaced.
